roadrash
cycle chatterer
- sitting on the edge of wigan pier
Perhaps they are for delivering power to your rear light. Some mudguards have metallic strips in them for this purpose but if they are not properly grounded, cannot work. Those are probably grounding cables.
Can I have the conducting strip to go with them as well?
Of course, your are right. Your knowledge of bipedal electrics is better grounded than mine.Aye laddie, power to the rear light of my Saracen goes via these and through the mudguard, the ground being through the light mounting onto the rack.
I've just taken delivery of a dynohub and lights and installation is proving to be a monstrous PITA, requiring extensive research, having been supplied only with some scant instructions, mostly in German, and a billion tiny parts some of which are vital and some are surplus to requirements. The only reason I was able to reply was because I'd just been reading up on the subject, and had just read a piece on mudguards with conductive strips.
Incidentally I don't think frame ground is used much these days. Most dynamos seem to feed power out through two core wires to plastic bodied lights that aren't grounded to the frame. But I could be wrong because this is a baffling subject that is doing my head in.
I think I've got it sorted now, thanks. Just for fun, here's what I'll be doing:
Shimano Dynamo output labelled "earth" -> B&M Front light in labelled "-"
Shimano Dynamo output labelled nothing -> B&M Front light in labelled "+"
B&M Front light out labelled "+" -> B&M Rear light in labelled "+"
B&M Front light out labelled "-" -> B&M Rear light in labelled "-"
The USB gubbins is integrated with the front light, thank goodness.
Put like that it seems deceptively simple, but it's taken a LOT of web searching to get to this point. I must have read a hundred forum posts wittering on about cabling. The kit comes with lots and lots of bits and pieces some of which are needed, and some are for use only for other kinds of dynamo. I think I have finally identified all the required/non required bits. I'm now worried that when I fit the lamp behind the front brake the fork crown bolt is going to need a longer replacement. But I haven't got to trying that out yet.
Next task will be figuring out the optimal cable routing that doesn't look too horrible (along the top tube probably). And then wrapping my frame in miles of insulating tape and making it look horrible. Then cutting the wires too short and having to go and buy new ones (probably).
Yes, they do feel notchy. However, it adds nothing to your ride. You will not feel it.@Yellow Saddle wow that's all super elegant. Too elegant for a duck tape merchant like me.
For now I just want to get it all working.
The stiffness and notchiness of the dynohub is much more than I expected. But once it's all together with me sat on top I don't suppose it will make much difference. Maybe add a few minutes on to my all day rides.
