Illaveago
- Chippenham,Wiltshire.
So that's where the bars go ! I think I've got mine the other way round. No wonder it feels twichy!
moving the seat forward was probably a big mistake and a common one with 'beginners'. Get the seat back and you'll probably be fine. Don't grip the bars tight unless it's a fast bumpy descent, and if you are heavy (what is your weight?) make sure the bars are not too lowThanks for the great replies, Going to change 2 things! first of I went out at got some gel padded fingerless gloves what are a but more of a loose fit.
Now the biggie, I originally moved the seat forward thinking that would make me sit more up right and take the weight of my hands. I will move the saddle an inch back and try it out. Been working on core strength at my local gym too
Is there any way of knowing or finding out what length of stem to use before I just start buying?
Rog
I haven't tried to ride any distance one handed, as around here your either going up or down, my previous bike a Trek hybrid was more comfy and my hands didn't go numbWhat happens if you ride mainly on your right hand ? Also did you get the problem before you switched to drops.
Visually everything looks straight and both brake hoods look the same heightYou say you get it in the left hand only, so it suggests some imbalance or difference in the way you use your right and left sides.
Are you sure the saddle is absolutely straight on the bike? the same for the handlebar angle - is it absolutely at 90 degrees to the wheel, and are the bars centred correctly?
Are the levers in exactly the same position on both sides?
I weigh in at 82 kgs now, how would I know if the handle bar height is adjustable?Don't grip the bars tight unless it's a fast bumpy descent, and if you are heavy (what is your weight?) make sure the bars are not too low
82 kg isn't much so I doubt your weight is a significant factorI'll try and answer some of the questions but first what is a 'cyclechattist'?
Rog
Hmm, tricky question ...I'll try and answer some of the questions but first what is a 'cyclechattist'?
If I had to guess, I would suggest that it is one of the people who 'chat' on CycleChat!![]()
