gilespargiter
- N Wales
I've never removed a cassette but have taken quite a few freewheels off over the years. With a freewheel all the mechanism is in the block which screws onto the hub. With a cassette, the freewheel is part of the wheel hub called a freehub. If there is any slippage of the cogs it may mean the pawls in the freehub are slipping as the cogs slide on splines of the freehub.
LBS need to sort this as this is usually a problem with old bikes not one as new as yours.
If it is the freehub slipping it could need a new wheel as that would be cheaper than rebuilding with new hub.
Just a small point here, but regarding the above couple of posts and the one quoted.
A freehub takes only moments to change and does not require a new hub.
Remove the axle, remove the cassette, insert a 10mm allen key into the one way clutch (freehub) engage it and unscrew the bolt (which the axle passes through) - hey presto one way clutch in hand.
for no logical reason.
