slowmotion
Quite dreadful
- lost somewhere
I have an ancient soil pipe that I messed about with a while ago. The messing went pretty well but I have a problem with a disturbed waste pipes that feeds into it.
It's common knowledge that the rubber seals on waste fittings go belly up and embrittle and leak after 15 years or so. The good news is that the weeping water from the seals evaporates really slowly and leaves a crust of mineral deposits ( not unlike the hard stuff in your kettle), and this plugs the leaks.........until they get disturbed.
I've done a lot of disturbing in the last couple of weeks and this bit is leaking. If I flex the pipe to stuff in a new seal or whatever, a pipe somewhere else will start getting all arsey. I'll probably be chasing leaks all over my home. Is there a wrap tape, silicone mastic, bitumen gunk, or whatever that you would recommend? I'm veering towards rubbing off the mineral deposits with a pan scourer, drying, cleaning it thoroughly with IPA, and wiping it all over with a huge amount of sanitary silicone, but it's a bodge .
What would you advise? Here's some music.....
[media]
View: https://www.youtube.com/watch?v=ZmopROxBnBU
[/media]
And thanks.
Edit: On the right is a vertical (nomimal) 100mm UPVC soil pipe. It has a clamp-on boss to take a push fit (32mm?) waste pipe. The rubber seal on the boss is clearly fubared.
[media]
[/media]
And thanks.
