billy1561
BB wrecker
- North west England
You must be delighted with the loss Rob. Must be a massive improvement in the climbing i would guess even though at your previous 13stone you were hardly overweight.
Not quitehello i have gone from 120kg to 91kg in 8 months, if you work out your BMR -300-500 cals from your daily eating weight will fall off
any questions please ask
29 kg in 8 months is about 64 pounds in 35 weeks or approximately a 915 calories a day deficit off TDEE, so 300-500 calories off BMR doesn't sound too far off.Not quite
BMR = Basal Metabolic Rate, the number of calories you would burn if you stayed in bed all day i.e in a completely rested state.
You presumably meant TDEE which is Total Daily Energy Expenditure; the amount of calories typically burned in a day, and dependent on your level of activity.
But that is not an effective way to do it as it is inaccurate and takes no account of activity level.29 kg in 8 months is about 64 pounds in 35 weeks or approximately a 915 calories a day deficit off TDEE, so 300-500 calories off BMR doesn't sound too far off.
You seem to have forgot to multiply your BMR by activity level. 1517 x 1.9(extra active) is 2882, you listed your TDEE as 2881.But that is not an effective way to do it as it is inaccurate and takes no account of activity level.
Typically, you need to save 3500 calories to lose 1 lb of fat, which is 500 calories per day for a 1 lb weekly weight loss. That is 500 calories less than what you expend on a typical day, i.e your TDEE described above. Sure, if poster was to eat 300-500 less than their BMR they would certainly lose more weight but probably not in a healthy manner.
For example by BMR is 1517 and my TDEE (based on ridiculous amount of exercise I do) is 2881. I know that if I eat 2881 calories per day then my weight stays stable. Now if I wanted to lose a little weight I simply cut back on my TDEE; at no stage would I consider eating anywhere close to my BMR.
Now I don't know particular circumstances of the poster wishing to lose weight, but using TDEE as a starting point for weight loss can work for everyone where invariably using BMR is not effective.
So BMR is effective when the math is done correctly![]()
Once the weather improves you will soon get it back!No change this week, mojo totally gone
13st 5lb.
