jay clock
Massive member
- Hampshire UK
I have an Endura Air Defence jacket which is quite good for the winter but I find it gets very moist inside - when I take it off I can feel a layer of damp all over the inside. this is it http://www.cyclestore.co.uk/productDetails.asp?productID=9311&catID=206
It is better when at lower temperatures but between about 7-11 degs I tend to wear a short sleeved base layer under it.
I am not particularly after a waterproof jacket, although the Air Defence is the sort you could manage with for a while in showers or light rian.
I am after something similar which I can wear with either short sleeve base layer, long sleeve base layer or both in really cold weather, and will work in a non sweaty way from about 12 degrees downwards. Perhaps if I used something different from 7-12 degrees I might avoid the sweat problem.
Price is not a particular issue as I am planning to get this as an Xmas prezzie!
