theboxers
TheBoxers on Cycle Sim sw
- OTC (on the couch)
@CXRAndyThe shaft has a shoulder for the slotted pulley to sit against. The pulley is slightly longer, so a thin washer cups when torqued down. When you remove the pulley, see if you see any brown powder around the shaft and bearing surface. This will be the first clue to the extent of damage.
At this point you could see if the flywheel will rotate when gently pushed and settle on the heavy side(put a sticker or mark the flywheel to see if it returns)
You could remove the rubber seals from the bearings, this is where most of the stiction drag comes from on bearings, along with washing the bearings in solvent and reapply a thin oil as opposed to grease. If these two methods help the flywheel rotate in the turbo then there might not be need to build a jig.
. Also listen very carefully when the belt is off for a tiny click or knock as the flywheel is gently rotated by hand. It will tell you that there is a flat spot in the bearings.
Yeah, about that.
Any advice and/or suggestions with regard to getting the pulley off. Everything I've tried just ends up going nowhere. I tried pulling it by hand, whacking the loosend bolt head with a hammer (soft faced) to push the spindle out and a pulley puller. It ain't shifting.
It seem to be stuck/welded to the spindle.
I'm obviously not at mechanically inclined as I thought I was
