Threevok
Growing old disgracefully
- South Wales
May I add, if you are using a BB that has one plastic cup, DO NOT grease that side
I think i do sometimes.May I add, if you are using a BB that has one plastic cup, DO NOT grease that side
You think the problem is that the grease degrades/cracks the plastic?
I assume the metal ones are functionally the same as the plastic ones across shimano BBs so you can just re-use your well greased metal ones?.....have replaced and removed many BB's in my time. Personally, I hate the ones with a plastic end cap, they always bind up after screwing on about half way. Steel is real.
OK, so 'hate' is a rather strong word - it would be fair to say I dislike them immensely![]()
I've never met a cartridge BB I couldn't get out.Disagree. Strongly.
A good idea to remove cartridge BBs carefully (and replace carefully) now and again and regrease. It's possible for them to seize in place otherwise.
Square tapers are so damn reliable that waiting until it needs replacing may mean you can't get it out.
Happened to me with my first proper bike.
Luckily a bike shop was able to extract it and save my frame.
I would always remove a cartridge BB on a bike soon after buying it. And cover threads in grease.
I would say functionality is the same, plastic ones being the cheaper option. As for budget BB's, have used VP brand, which I believe is exclusive to Halfords? Anyways, they are all metal, and no complaints......I assume the metal ones are functionally the same as the plastic ones across shimano BBs so you can just re-use your well greased metal ones?
I have the idea that un55s use metal. Un26 plastic. Folk feel free to correct/educate me.
I hate the plastic ones, many a time i have stripped the threads on the plastic side .
I didnt think you were supposed to grease square taper crank arms ?
endless debate on that.I didnt think you were supposed to grease square taper crank arms ?
, now comes in a handy pritstick style thingy so I just leave it on the bench.
[/QUOTE
isn't that threadlocker, not copperslip?
basically, pretty much anything metal on metal, grease it is my approach.
BB shells I use Shimano anti-seize paste.
