Vittoria Rubino Tyres
I need a new set of tyres and was looking at the Vittoria Rubino Wire Bead clincher tyre. Then I saw the Vittoria Pro Rubino Folding clincher tyre.
Can someone tell what the difference is (apart from price) and whether the latter is worth the extra tenner.
Lee_M
eaier to stick a spare tyre in your back pocket!
400bhp
From Wiggle:
Top Features of the Vittoria Rubino Wire Bead Clincher Tyre
The popular all-rounder Rubino has the perfect mix of features for most amateurs, with the endurance for the toughest challenges. These tyres are robust 60 TPI nylon casing, have a technical tread pattern and long life tread compound.
  • Ideal mix of features makes it the perfect all-rounder
  • High mileage tyre designed for long service life
  • Secure and comfortable, with a wide choice of colours and sizes
  • Sizes: 700x23, 700x25
  • Weight: 305, 345g
  • Max Bar Rating: 7-10
  • Max PSI Rating: 100-145
  • Road
  • Weight (g): 305
  • Tyre Bead: Wire
  • Threads Per Inch: 60
Top Features of the Vittoria Rubino Pro Folding Clincher Tyre
The popular all-rounder Rubino has the perfect mix of features for most amateurs, with the endurance for the toughest challenges. These tyres are robust 150 TPI nylon casing, have a technical tread pattern and long life tread compound.
  • Weight: 225, 235g
  • Max Bar Rating: 7-10, 7-9
  • Max PSI Rating: 100-145, 100-130
  • Road
  • Weight (g): 225
  • Tyre Bead: Folding
  • Threads Per Inch: 150
Deleted member 20519
The folding versions fold (believe it or not) and they're a bit lighter. I bought the standard ones and I've had no issues with getting them on or off, not worth the extra money IMO.
400bhp
That's actually quite a lot of weight difference on the rim.
200g for £20 is I think pretty reasonable if you're interested in that. [caveat-assuming the weight is correct for the tyre size you're after]
gaz
Cycle Camera TV
South Croydon
Despite the obvious differences of one being a folding tyre and one not.
The wire bead has a 60tpi and the pro has 150tpi.
A higher TPI means that a thiner thread was used to form the basics of the tyre, this makes the tyre lighter and decreases the rolling resistance. However it is more easily damaged by stones etc..
I went from folding Zaffiro Pro tyres to rigid Rubino and I can safely say that I do not feel the slightest bit of different about the 200g of weight saved.
400bhp
Up a hill?
Difficult to physically tell, but (and this is the key) if you're interested in shaving the odd seconds off here or there it will make a difference. It has to.
Up a hill?
I saved 1kg when I got new wheels, that made a difference - did 200g of tyre make a difference? Possibly but I highly doubt it.
ianrauk
Tattooed Beat Messiah
Rides Ti2
I have used both tyres over many thousands of cycling miles.
Both tyres are really excellent imho, good puncture proof, grippy and long lasting.
If you are a weight weenie then get the Pro's, if not then get the normal ones.
