Alex321
- South Wales
We stop where common sense dictates.Where do we stop? Knee pads, inflatable bump suits, cycles only in yellow, no cycling after dark just in case?
If the conditions are such that most motor vehicles are driving with lights on, then we should be putting them on when cycling as well.
If your personal common sense says it is better to have them on all the time, by all means do so, although I think they make little difference in clear daylight conditions.
If you feel you are likely to frequently come in contact with the ground, then knee pads may well be a good idea for you - most mountain bikers do wear them, most road cyclists don't see the need.
