Yamyamsteve
Regular
Any suggestions for cleaning up the wheels? Was thinking of a very fine wet and dry to remove the light rust
Hammerite rust removing gel is good for chrome, tomato ketchup is also supposed to work as does cheap colaAny suggestions for cleaning up the wheels? Was thinking of a very fine wet and dry to remove the light rust
Thought that was only any good on newer chrome.Hammerite rust removing gel is good for chrome, tomato ketchup is also supposed to work as does cheap cola
Used foil dipped in a vinegar and salt mix ... worked well , currently got saddle soaking in coke as springs hard to reach to cleanThought that was only any good on newer chrome.
cheers .. I have mailed pics of what's left of decals to hlloyds see if they have anything similar but no reply as of yetThe only thing I can offer at present, is the headbadge appears to have first been introduced in 1962......for the sports range.
The chain-guard & paint scheme look 50s?.
As in the frame number?The number should be on the bottom bracket though.
AyeAs in the frame number?
Having major hassle getting them out I know that much!! Need to knock up a press type tool as I'm struggling to see any for saleAre the cotter pins worn, or is it just the picture?
Raleigh Esquire 21 - 22 Inch Ladies Bike?
@1980
