I discovered a catalogue which shows the Black Diamond without chrome forks .Yes, I thought that too after seeing some brochures on the internet. Looks like it has been repainted, which is most likely the reason no decals exist now. The head badge is a foil one so they might have got it off and reglued it afterwards.
So mine might be original paintwork then? I do wonder what happened to all the decals though. They haven't worn off, that's for sure.I discovered a catalogue which shows the Black Diamond without chrome forks .
I think around the mid 60's Falcon seem to have switched to vinyl type stickers. Mine are curling back around the edges.So mine might be original paintwork then? I do wonder what happened to all the decals though. They haven't worn off, that's for sure.![]()
Why don't you give the frame a T cut or something similar, fit some alloy wheels and get it going again?I have a Falcon frame:
It was a complete bike when I got it but at 23" its slightly too big for me, so I used the parts on another bike. I think this is a Black Diamond but it had lost all its decals except the head badge, which I removed in order to have the frame powder coated (its in the photo resting on the BB).
This is the bike when I bought it:
Now I've had second thoughts about the powder coating. I don't think I would recover the cost of it if I sold the frame afterwards, or even if I rebuilt the bike. I'd like to maybe swap it for a smaller frame of some sort and maybe build a bike I could actually ride!
It could be that you are right. The style of transfers would suit a later period.The Falcon I own has the frame number M910323 It is stamped at the bottom of the seat tube near to the bottom bracket. I thought it was a 1978 /9 model.
I will take the calipers off and have a look.It could be that you are right. The style of transfers would suit a later period.
Have you checked the back of the brake calipers for a date stamp ?
It is just a theory I was trying out.
Had a look, but no date stamp anywhere. They are Shimano Tourney centre pull calipers and the only stamp is "Japan"I will take the calipers off and have a look.
I went and had a look at my Black Diamond. The number is stamped into the bottom bracket C 24547. I looked for a date stamp on the rear Weinmann 730 side pull , it to hasn't got a date stamp either . I'm not sure what I did with the front one .Had a look, but no date stamp anywhere. They are Shimano Tourney centre pull calipers and the only stamp is "Japan"
I'm sure now that the paintwork is original, because somebody scraped some off to see the frame number more clearly and the blue is the only paint on there. If it was resprayed it must have been a long time ago. The blue paint does have some black touch ups where I presume there were rust spots. Why the owner didn't use blue paint I don't know but the black seems to be a bitumen like paint, so it may have been to stop the rust coming back?Why don't you give the frame a T cut or something similar, fit some alloy wheels and get it going again?
My Black Diamond has been utterly transformed after fitting some alloy wheels and double clanger and is the most ridden of all my bikes .
