The Shimano kit is 1986, 600 and 105. I would say the frame is older than 83 with the above BB chain guides and square fork crown.
The frame will be worth a few bob to a collector.
Where can I find a collector?
Yep, bikes of that era had cut out lugs and panto work to set them out from the crowd...
I would expect a Colnago of that era to have cloverleaves somewhere ?
Shaun
Looking at the lugs and dropouts, it's not a colnago, sorry. The drop outs, where the wheel goes, will have colnago engraved. The lugs are too plain.
Sorry didn't look close enough.
Any serials on the BB shell (under the bike).
It's still a decent frame - Reynolds 501 as a minimum as the seat stays are quite thin, which is what better quality steels could do. It's not 'gas pipe' so don't worry if you are disappointed.
More likely to be Columbus tubing (still very desirable)So it could be worth keeping?
Also no cable lugs on the top of the top tube.https://lfgss.microco.sm/api/v1/files/22f8164f16572ce6528616c3b292f45082f42acc.jpg
Decals in wrong place Similar but not the same
Note the cut-out in the bottom bracket.https://lfgss.microco.sm/api/v1/files/22f8164f16572ce6528616c3b292f45082f42acc.jpg
The '73 version of the bike. http://www.cycleexif.com/colnago-super-73I'll check for a serial number tomorrow.
So what is it worth? And why on earth would someone make a similar frame and put Colnago on it? Colnagolover on Retrobike said that it looks more like a 70's era bike. Would the clovers have been present in that era?
Too much high end, for it's day, components on it for an "old banger". You can see in some of the pictures where the oil/grease has dried out. BSA's can be worth a bit more than people realise.looks like any old banger to me, a BSA maybe![]()
