Ajax Bay
- East Devon
A six speed block will fit just fine on your current wheel. Don't waste time with more (ie than 6). A 14-28 freewheel is easy to obtain and the RDs of the day will work (I have a Campagnolo Nuovo Record Pat 76 which works with a 14-28 without hiccup).
The bottom bracket will be square taper. I would not fit a triple but find a compact (ie double) which fits the bottom bracket. Your FD, which will be friction, will likely work. And you then have a 34/28 (ie 33" length gear) which ought to get you up any hills you choose to address (YPMV). And a 50/14 (ie 96" length gear) which will take you up to a speed beyond which it's not really worth pedalling, certainly when out on such a bike.
Since you ask, I think that you are in danger of 'spoiling the bike' (OP's words) if you go further than this (a triple would be fine, but at considerable cost and faff). But I also agree with @mrandmrspoves , "Old bicycles are meant to be ridden".
You can but I bet the current RD would not operate with it (ie the one imaged).You can get big sprockets on a 5 speed block
Your crankset will probably not take a smaller chainring (well maybe a couple of teeth smaller but that's it) because of the BCD bitd.Old bicycles are meant to be ridden so go ahead and convert . . . Assuming you have friction shifters they will probably cope with an extra gear or two - but your derailleurs might not . . . . . You may be able to drop to a smaller double up front (possibly just a chain ring) and a wider range rear block - if it will achieve a low enough gear for you. So at best: swap front small chain ring (avoiding new bottom bracket and possibly new front derailleur)
