Velo Viewer
Solocle
Poole
I would presume that was quite a lumpy ride ?
I need three Ilkeston squares to increse my northern edge
Very lumpy indeed, although I did try to plot my route with elevation in mind, it was still +2000m over 110 km.
Spartak
Powered by M&M's
Bristolian
Thanks @13 rider my square total is 2543 & cluster is 406.... :okay:
Supersuperleeds
Leicester
Took the train to Fiskerton and rode 100km home with the wind behind me and bagged another 14 squares, some right bloody lumps I had to go up today. Really need to get fitness back, I was blowing like a whale up some of them.
Sallar55
South of Winchester, catching bits of the South downs way.
13 rider
leicester
Today's imperial ton ride targeted my top left corner just short of the peak District ,2 squares below Ashbourne gained 23 squares total now 5171 max cluster up 29 to 2692 . Need 7 squares between Derby an Ilkeston to increase my max square by 1 if I get the ones directly above them it will increase by 2
Solocle
Poole
On my phone it's called "explorer help for velo viewer " . Basically it uses GPS to drop your location on a map then you can overlay the grid . Very useful for tricky squares to confirm you got into the square
There's also Osmand Maps which can do similar, but it also stores your veloviewer grid offline. Most importantly, unlike explorer helper, it works on iphone.
