There is and I can extend my max cluster across it. But just beyond the mouth of the Mersey is the Irish Sea, and that stops my max square.
Could you get a boat to cover the Mersey? If you ran all the time, itd count in my book!
I've taken my bike on the ferries plenty of times, so maybe if I stayed sitting on it?Could you get a boat to cover the Mersey? If you ran all the time, itd count in my book!
Group ride yesterday which covered some new ground, and to and from the start/finish I took some diversions to fill in an island of 8 untouched tiles. Total tiles now 495 (+29), max cluster 165 (+25).Total tiles now up from 455 to 466, and max cluster up from 118 to 140.
I meant to say that part of the island of missing tiles is covered only by tracks and footpaths and I didn't know whether there was any way through, but I'd started early so that I'd have enough time to give it a go.Group ride yesterday which covered some new ground, and to and from the start/finish I took some diversions to fill in an island of 8 untouched tiles. Total tiles now 495 (+29), max cluster 165 (+25).
Target ride completed and max square up to 29*29 . Max cluster 1385 total number 3084 . The tricky square involved a tough track on which I punctured on . My first velo viewer puncture considered the tracks I've riden it's not too bad13 more squares today including todays target square which due to navigation error I had missed on a ride a year ago and in ended up on the bottom line of my max square and was only 26 miles away from home . 1 more targeted ride should see max square jump from 27*27 to 29*29 . Max cluster up to 1355
Target ride completed and max square up to 29*29 . Max cluster 1385 total number 3084 . Throne tricky square involved a tough track on which I punctured on . My first velo viewer puncture considered the tracks I've riden it's not too bad
Yes that lane . Gates were openYou know you've done a rough track when you discover a split rim or even a cracked hub
Was that the track from the bottom of the industrial estate and a couple of gates to lift the bike over? If so, we've ridden much worse.
