karan733 said:Does anyone know how to reduce the file size on the Md80 clones? I recorded my commute in today (33 mins) and it took up 2.65GBs! I only have a 4GB microSD it came with at the moment, but surely this cant be the cause of the problem?
karan733 said:I knew it! I dont have the hinged mount! I only have the clip for a coat or backpack or whatever, but no other mounts. I take it this is why I cant recreate what you've done?![]()
Mark_Robson said:there's an explanation on this site and a load of vids on youtube.
g00se said:B****cks! Yes - mine came with various clips, cables and charger in the box. There's an accessory pack for the original Veho Muvi - maybe that'll be the best route?
karan733 said:Well, ive managed to find a way to attach it without the hinged mount. Ill take pics tonight and upload them here, so if anyone else's comes without they might be able to recreate it. I used the same helmet mount from halfords, thanks for pointing that one out!
gaz said:Crankarm have you tried supporting the the camera, i use an elastic material that goes on the frame before the camera and then wraps around the camera to give me a steady shot.
cyberknight said:Give up !!
on charge for 3 hours and it managed 18 mins recording time![]()
cyberknight said:Yes it is a clone, cost £11.86 from hong kong.
After a lot of mucking about they are sending a refund.I guess mine was the duff one, i have ordered another with better buttons from a uk ebayer who said the one they sell does at least 1 hour at a time to a max of 2 hours.
Are you using the mains or USB charger cyber? I'm clutching at straws here but it may make a difference. I know that there are concerns about using the mains charger but mine has been fine. One issue that I did have with my clone was that the cable was a bit hit and miss, ie, sometimes Windows wouldn't recognise it, so I used another cable that came with a phone and it was fine. Also I read somewhere that if you totally flatten the battery it renders it useless. I have ran mine flat and it just switches itself off so I'm not sure that there isn't built in protection.cyberknight said:When the description says it records for 2 hours on a full charge i was hoping to at least get to work(40 mins)
