Valves
SWSteve
Bristol...ish
I am terrible at looking after the valves of my inner tubes, they're presta valves, I tore the twisty bit out of one when removing the pump, and another I forgot to put the dust cap back on, and now it doesn't tighten completely which means dust caps do not also tighten properly. Is it worth buying a bag of valves which screw into the tubes (I think this is possible) and is this even possible?
wisdom
Blackpool
Not really an option (just my opinion)tubes are so cheap now.
deptfordmarmoset
Full time tea drinker
Armonmy Way
I've only had a valve problem with Continental tubes. Well apart from cack-handed pump removal, that is. I now avoid Continental ones and take more care with the pump. It sounds a bit like you've bent the head of the valve if it won't retighten enough to get the dust cap back on. Not that dust caps serve any real use that I've experienced....
Shut Up Legs
Down Under Member
If you're careful, you can bend the head of a Presta valve back into alignment. I've bent these valve heads a few times, and (mostly) have been able to bend them back.
S
SWSteve
Bristol...ish
Have since put a dustcap back on...and the top of it has come off :/ I'm not hugely worried as can get inner tubes 3 4 10 at LBS so don't know. Knowledge of how to do things and how bikes work is something I do not have so will soon need to learn incase I have any issues.
sittingbull
South Liverpool
I find it reassuring to know that a rolled up spare tube is less likely to p******* itself with a cap in place.
Cycleops
Accra, Ghana
When removing the pump with the valve at twelve o'clock bang the pump down with your fist instead of try to twist it off. No more broken or bent valves.
youngoldbloke
+1
- and dustcaps are only useful to prevent damage to the tube when folded or rolled up. Also the threaded valve collars serve no useful purpose. Leave them off - enjoy the rotational mass saving benefits :hyper:
Dan B
Disengaged member
I duct tape them to the spoke opposite the valve hole so that the valve doesn't unbalance the wheel. This is an especially serious problem with the long valve stems that seem so popular nowadays
Cycleops
Accra, Ghana
+1
Also try leaving the change out of your pockets, although this doesn't affect rotational weight, but you could try leaving your socks off.
youngoldbloke
I only carry notes ....... :biggrin:
Yes indeed - and not widely appreciated. I expect Team GB have an answer for this - it's all about marginal gains, I believe ;)
