Debian
- West Midlands
Ian H said:Yes, mine's mostly on-road. I've had no more trouble with presta than schrader. Only presta works with deep-section wheels.
It's not so much troubles with the actual valve but the inconvenience of it. It's so easy to bend the pin on a presta, which means a replacement tube if you don't take the pump off properly, you can't replace the insert if it develops a leak and, in an emergency, you can't use any old cycle or car tyre pump on a presta as you can with a schrader.
I suppose for a specialist wheel a specialist valve has a place but I've come across many a wheel that could just as easily take a schrader but it's supplied with a presta - why? Maybe because it's more cool to be seen with prestas? Are you not considered a "proper" cyclist unless you have presta tubes? Dunno.
