My entry into silly question of the year:
When riding a triple you're advised against being in the small crank at the front and the small at the back and vice versa to avoid twist and therefore wear on all the components. This makes sense.
Does this apply when you have a double as well with only two at the front? This would start limiting your choices wouldn't it?
but the gist of it appeared to be similar to the above, its still bad practice
