lantern rouge
- stockton on tees
I don’t think I’m using my gears correctly, For my “quickest” cruising on the flat for long periods, I still have 3 cogs left to use, and I am spinning at a high cadence (question later)
Is it just a macho thing that you should be grinding away in “top” as much as possible?
If I change up a cog, I’m struggling to maintain roadspeed ,cadence and lose style/composure.
Do I need to learn technique, get fitter or get the gearing changed?
I also don’t use the inner/smaller front ring –again poor technique/gear management? How do you guys use it?
How do you measure cadence? One complete revolution by one pedal or, count every time a leg moves downwards ie, every left/right movement = a count of two (I’m losing myself now!)
F. W.I .W ,I’ve got 8 cogs on the back and a compact double on the front
The way it’s going , I could save weight and go to a single cog on the front!
