Must be a really wide road if you cycle there.Have I mentioned I live across the road from a pub.![]()
And a bottling once in a while? (After £20 worth of pints?)Ooh, you can’t beat a flat roofed pub, two quid a pint and usually a decent cheap roast on a Sunday!
http://www.ilovebicycling.com/training-perfect-pedaling-technique/
Pedaling the bicycle is what cycling is all about!
Yes because those are utter bollox.
I'm having physio to try to get my knee to bend enough to be able to clip in again comfortably...I need at least 10 degrees, 20 would be perfect.
I'm ok on flats for short distances currently, but I'm meant to be doing a 100 in August and going that far with my heel or at best arch on the pedal is going to give me hip and ankle pain (all I can manage at present on the left side), while being clipped in will put my foot in a far better position.
Nothing to do with being a proper cyclistjust a comfortable pain free one
What position can you achieve using clips that you cannot achieve with flat pedals?
I've had quite few clipless moments, especially riding fixed, but now I disengage my right foot before I need to and sometimes both if riding on bumpy ice. I have 2 pair of the kind that are regular flat pedals on one side and clippers on the other for my favorite 2 bikes, so I can ride in bike shoes or Crocs or Sorel snow boots or flipflops as I wish. I use anti seize compound on the pedal threads so I can switch SPDs for flat pedals easily. My SPDs have held up well for many years, BTW. I am a grinder, not a spinner, and as such pull up as well as push down going up short steep hills. To open up another can of worms, I prefer stiff shoes to soft bendy ones and so my bike shoes have the SPD cleats attached. I recall the very light, very tight "italian" bike shoes with lead cleats and toe clips and don't miss those at all. We used to get them wet so they would stretch to fit and always reminded me of Chinese foot binding.
I'll second that. Went clipless early when I got back into cycling but didn't fancy road cleat as I like to be able to walk, so went MTB. Got the hang of unclipping quickly, only fell over twice, fortunately onto grass both times and nobody watching.Riding fixed without being clipped in is particularly difficult when you hit a downhill stretch, and you don't see track riders that are not clipped in.
I'd advise anybody thinking of going clipless to do it first with mtb pedals,since they tend to be a lot easier to get in and out of than road pedals, with the benefit of being able to walk when you get off the bike, and therefore better for a commute. The learning curve is higher with road clipless.
I can’t pedal with the front of my foot (ie ball of foot just behind toes) which is where clipless positions the foot (even with cleats as far back as possible). I don’t have the required flexion to turn the pedal without excruciating pain. On flats, I can position the pedal below my arch or heel as less flexion is needed. However, that then affects other joints like hip and ankleWhat position can you achieve using clips that you cannot achieve with flat pedals?
Never done thatThe one where you lay on the road on your side still clipped in![]()
