Hi TheDoctor. I am truly sorry to be a little slow here (onset of dementia fever) but the external diameter is all but a whisker the same diameter all of the way down to the Crown Race position.
I currently have a pair of 1" 'A' head thread-less  forks with a Campagnolo Chorus headset secured with the standard star washer,cap and bolt along with a shim fitted for a stem.
I cannot see what difference a portion of thread would make because the whole assembly relies upon the downward force of the bolt and washer biting into the internal bore. The shim would cover the threaded portion ready to accept the 1&1/18th 'A' head stem.
I think you are mistaken in that you think the star fangled nut / top stem bolt assembly does anything other than taking play out of the fork/headset/stem assembly and correctly preloading the headset bearings. What actually keep the bars/stem securely attached to the steerer are the two horizontal stem bolts clamping the stem on to the steerer.
And therein lies your potential problem. If the steerer is threaded anywhere above the headtube, your plan has a weakness never designed for because the thread was designed for nothing but to let the top traditional headset nut taking play out (just like the star-fangled nut/top bolt for aheadset). The threading would have significantly weakened the steerer for taking any lateral or clamp load, which would be exerted by everything including the headset, stem and of course handlebars above the headtube. I would certainly not recommend it.
A threaded steerer, as you know, is bound to the stem via the stem bolt and "expanding" wedge assembly inside the steerer tube.
