MajorMantra
- Edinburgh
Manonabike said:In my upgrade I want to replace the '7' shaped stem for one that can be raised a further inch.... I'm looking at these two following components:
1.1/8"
adaptor
and
stem
Also, the headset appears to be in good healthbut I would very much appreciate it from those that have done this kind of upgrade to point me the direction of a compatible headset.
One more question, if I may, after removing the fork, I could not remove the ring that sits at the bottom of the shaft and holds a rubber seal before the bearings. It seems that is stuck there or perhaps is not supposed to come out. There is no damage on that but I would like to know if that can be removed if I need to in the future.
Thanks for all the advise.
MajorMantra said:It's a matter of taste but I think older steel frames look best with a quill stem (the 7 shaped kind you're talking about). They come in a huge variety of sizes - try ebay or somewhere like SJS Cycles.
Matthew
GrahamG said:if you want anything more than a 12-26 as the largest sprocket then you'll have to fit an mtb rear mech to cope with say an 11-32.
Manonabike said:but it's worth every penny
I'm having such fun.....
porkypete said:Sheldon reckons the road mechs will cope up to a 30T rear (although Shimano say 27T maximum. Thanks to the genorisity of another member donating spare sprockets I am going to able to check this out for myself shortly.
