Upgrading cassette and chain
Citius
I don't see anything misleading about it at all. I said gear choice is a balance. You will gain as much height as you lose - that's all there is to it. If your 20 mile ride is 1000ft down hill, it will also be 1000ft back up again. If you are descending a 1% hill, you won't be spinning out on an 11t. Nor will you need a 32t to get back up it. But you will still do the same amount of work, regardless.
edit - let's use height, rather than miles.
That's exactly my point, thank you. :smile:
SpokeyDokey
69, & my GP says I will officially be old at 70!
Hi
My Cube Peloton road bike currently has a Shimano Tiagra 12-32T 10 speed rear cassette on.
I was thinking of upgrading/changing to a Shimano 105 6700 11-28T cassette. This will then be a full 105 gear/chai set and better gearing I hope.
Will I notice much real world difference? Both in top speed (I often spin out on the 12 I have) and/or climbing the local hills?
I can't find a 105 10 speed chain anywhere as they look to be discontinued. Would something like this be OK? http://www.chainreactioncycles.com/shimano-ultegra-6701-10-speed-chain/rp-prod55029
The fitting/ replacement looks relatively straightforward but I don't have the specialist tools so was thinking it'd be better to get my LBS to do it. Is it better for me to by the tools and DIY or am I likely to only need them next blue moon!?
Methinks this is what's bugging you. Forget it - they are just bits of simple metal.
Buck
Buck
Yorkshire
TBH I wasn't sure if having all the components the same was 'better' but it seems that we can have a veritable pick 'n' mix :smile:
I'm going to monitor my usage of the gears over the next few weeks and see if I would miss the easiest couple or not. I don't want to gain the 11 then find I'm missing the 30! After all it is a bit on the hilly side around here ;)
SpokeyDokey
Good idea.
The 'big jump' thing on the cassette doesn't bother me. In fact he individual gaps don't even register as significant differences on my Tiagra 12-30. It all feels like a nice set of well spaced steps as I shuttle up and down the cogs.
There's always a widely different set of views on what is right about all aspects of bikes/cycling. Different people have different needs based on their fitness, type of riding and where they ride etc.
For me, I live in a hilly area, am pretty fit, although that is only in a small part cycling derived, and would be classed as a casual cyclist (2000 miles pa/low motivation to get out there) and need a range of gears that gets me up and down the incessant up & downs of the Lake District.
My 46/34 and 12x28 works perfectly for me.
With a 53/39 and 11-23 fitted I wouldn't be able to cope but for other people that might well be the holy grail of cycle gearing.
I am one of those who hate feeling like a should change up, or down, but know that the next gear I have will be too big or too small respectively.
I do I agree that were all different though and some can accept this scenario without any complaints.
Would I not ride a wider range cassette with bigger jumps, no. Would I like my everyday bike to be this way, no.
