gbb
- Peterborough
A little input if you will...
I currently run Xenon 10 QS speed (on a 2007 bike)
The 10 speed Xenon ergo is on the r/h side. I won a 10 speed Centaur shifter on ebay with a view to slowly upgrading....a couple of questions
a. Does it go without saying they are compatible.
b. The Centaur 10 speed is l/h mounted. Is that normal ?
c. The upshift lever sits slightly to the outside of the brake lever, so they dont line up. Is that normal, or because of wear.
It was relatively cheap, so i'm not heartbroken if i've goosed it compatability wise.
Any thoughts ?
Any thoughts ?
