david k
Hi
- North West
i aimed to achieve a good distance - 40 miles is a good distance for me and a good average 16mph is good for me. I had little left in the tank so wondered if given that anything could be made of the said data
I find it useful for tracking the peaks and troughs, a part of my commute ride where I regularly get to roughly 85% of max I can then coast or gentle pedal down the other side for two minutes which gives me a rough guide to my HR recovery. By hovering over I can get the 1 minute and two minute HRR.Rather contradictory, I find one of the most lacking area's of Garmin Connect to be anything related to heart rate!
If your aiming to achieve distance then your HRM is not needed...
If you mean you want to analyse this information and apply fitness as 40 miles is your target distance then by only doing 40 mile rides your not going to see much improvement as you will plateau.
would you expect to see a change in the 'zones' if i did the same distance in the same time but got fitter?
ha ha, very trueIMO, it would probably be quite beneficial for someone to write a sticky on basic HR training, equipment, basic features, testing protocol's, setting up your zones and understanding them, basics of training to HR, recommended reading, FAQ's etc.
Problem being, it takes time and effort, requires a little bit of knowledge, is open to criticism and it is probably going to be a fairly thankless task so there is not much motivation for anyone to bother.
ha ha, very true
for me knowing if the stats back up how i felt is enough, i thought id worked harder than these stats suggest!
I don't really understand what you mean in the second part.
That is related to the point I was making re. the distribution being rather polarized (a disproportionate amount of time spent either at very low or very high intensity zones). All that time accumulated in the anaerobic zone will have done damage, so even when working below that intensity, you may have had an elevated rate of perceived exertion.
A HR monitor is never needed, however, it can be useful with regards covering a new, increased distance.
The trouble with this statement is, you need a starting point. If you are not using heart rate as a starting point what are you using ?
