Ultegra Di2 front mech failure
When CFRP works right (and the fibre type / lay-up is correctly designed for the task in hand), it's bang on. If it's injection moulded chopped strand, it should be pretty strong in all directions of load.
Looking at the failure, it seems to me that there may well have been an air bubble along some of the fibres - which points to a manufacturing issue. You *really* don't want air bubbles in composite structures...
That 'failure' has written off a very expensive component though. OP needs to see what Shimano/UK Distributor says.
FishFright
More wheels than sense
Sorry. Maybe those old fashioned cable operated things aren't so bad after all ^_^.
Thats an odd kind of sorry lol
JhnBssll
JhnBssll
Suffolk
The actuator drives the metal backplate, That's correct. Any force applied to the chain is transferred through the failed linkage due to the pivot positions. Upshifts put the part in tension and downshifts put it in compression
Reynard
Yes, of course.
But bottom line is, there shouldn't have been a catastrophic failure like that - usually such a failure would require a pretty significant impact. Therefore seeings that the component was almost new, correctly installed and well-cared-for, the only other conclusion is that it was flawed from the start.
Get onto Shimano/UK distributor. My experience of Shimano Mechs, is they are flawless. Had DA/Ultegra/Deore LX/XT for many years and they just work.
SRAM are the buggers for going 'too lightweight' on their MTB Mechs. My X9 is a bit 'skinny', but it works - it's not as tough as my 20 plus year old XT mech.
JhnBssll
JhnBssll
Suffolk
I think it must have been flawed or damaged as you say. I've read reports of them lasting 15 to 20 thousand miles, the 200 miles this one has done should have been 1% of its life, not 100% :laugh:
Ah, new - back to shop for a new one.
JhnBssll
JhnBssll
Suffolk
Quick update on this. I had confirmation today that a new Mech has been dispatched. I'm obviously pleased that they're replacing it but I'm disappointed it's taken them this long to dispatch it and also unhappy with their communication; I asked for them to send a replacement in time for this weekends ride and gave them my number to call if there was a problem. They received the failed mech on monday at 9.27am and yet it took them 4 and a half working days to send a replacement, and even then they sent it by standard royal mail with a 3 to 4 day delivery time. Most irritating.
