If you're buying a new bike from a LBS then you could ask them if they would swap out the rear mech and cassette for the spec you're after.I was thinking of getting a new bike with Di2, rather than swapping my current 105 groupset.
£20 for a di2 rear mech???I run Ultegra Di2. Had my Cervelo converted for France this June. Was running 11-28 with 52-36 up front. Bought compact Rotor chainrings, and then the GS rear mech for around £20 from SJ Cycles, an 11-32 cassette from Wiggle and engaged a friendly bike mechanic. Job done
Great, thanks. Good to know that this configuration is possible.I run Ultegra Di2. Had my Cervelo converted for France this June. Was running 11-28 with 52-36 up front. Bought compact Rotor chainrings, and then the GS rear mech for around £20 from SJ Cycles, an 11-32 cassette from Wiggle and engaged a friendly bike mechanic. Job done
Sorry, my apologies - mech cage. The mech body is identical regardless.£20 for a di2 rear mech???
You don't need to go to the expense of purchasing a long cage rear mech......you just need a woolftooth road linkGreat, thanks. Good to know that this configuration is possible.
In the Alps I had 50-34 with 11-32 out back. I wasn't aware of the Wolf Tooth Roadlink. Cost wise the plates that make up the mech cage are similar to the Roadlink.You don't need to go to the expense of purchasing a long cage rear mech......you just need a woolftooth road link
I use one on my etap so it takes a 40t cassette, it was an alps killer for me
But it's easier and less complicated for the newby mechanic to fit the woolftoothIn the Alps I had 50-34 with 11-32 out back. I wasn't aware of the Wolf Tooth Roadlink. Cost wise the plates that make up the mech cage are similar to the Roadlink.
34/40 was my lowest available, using sram etap........I could have gone to 42t as I was running a 46/34 upfront, but stuck with 40My solution was suggested by a tame bike mechanic friend who'd done similar conversions so I just let him get on with it. BTW what was your lowest gear you had available in the Alps?
I used a generic chainring from TA in black.........fits the sram red crankset no problem and means I use ,ore of the rear cassette using the 46.... for me it's a much better set-up. I'm also now back on a 32 cassette back here in South Wales I don't need the 40Mine was 34-32. It was all still a grind. Have Rotor chainrings, not come across an outer ring below 50 tooth.
I've still kept my 11-32 on for now but thinking of going back to 11-28 with compact for normal riding around here. Going to invest in some new wheels in New Year so will keep 11-32 on lightweight Mavics for France 2019.I used a generic chainring from TA in black.........fits the sram red crankset no problem and means I use ,ore of the rear cassette using the 46.... for me it's a much better set-up. I'm also now back on a 32 cassette back here in South Wales I don't need the 40
