maltloaf
- Gloucester
Hi,
I recently bought some Ultegra brakes second hand. They turned up and looked lovely so I thought no more of it.
My new frame arrived today so I started fitting them, but realised I have no idea where any washers go (if at all).
I presume the back nut goes through the frame/fork without a washer but then do you have a washer or anything before the main brake assembly ?
Also, the front brake seems fine but the rear has a far too long back nut, which is more than double the thickness of the brake mounting on the seat stays. I see on the shimano site that there are 3 different back nut lengths available but I don't have them. Does anyone have any idea what I could substitute in there ?
Back nut is #4 on the shimano doc http://techdocs.shimano.com/media/t...BR/EV-BR-6500-1681A_v1_m56577569830728758.pdf and there is a washer/spacer shown but not clear where.
Any guidance gratefully received.
The perils of buying secondhand gear I suppose...
Many thanks in advance.
Kevin.
Kevin.
