- South Manchester
Definitely NEW BIKE time.
Looks and sounds pretty straightforward to me (just watched a Tube video as well).just google inline gear adjusters or barrel adjusters. assuming you are running 4mm outer gear cable then you need the 4mm models (5mm is for Brake cables) quite simply the gear cable just inserts at either end (no ferule needed, but a good clean straight cut is advisable). you twist it and it lengthens / shortens your effective outer cable length and thus adjusts the cable tension.
very easy to fit. Fit them in the run between the bars and where the cable enters the frame:
Remove inner cable (you can just retract enough so it isn't in the bit your snipping, but still in the run beneath the bar tape) snip and tidy ends of your outer, insert and re thread the inner cable - there is normally some sort sort of bung you can remove to find the inner where it exits the frame, and reattach inner to the mech in question.
omgDefinitely NEW BIKE time.![]()
Nobody on earth will successfully drill out a 2.5 mm ball end from an allen key, that size is easily snapped off regardless of the quality of the key, even the larger sizes will be nigh on impossible to drill through due to the hardness of the metalCheap hex key will be soft metal. Drill and put in screw and pull. Or if you can get depth correct, use compressor air line to use pneumatic force. Can be very powerful
It's recessed by the width of a gnats cock.The snapped bit appears recessed into the bolt head a tiny bit.
Have you tried undoing the bolt with the other end of the allen key or a flat bladed screwdriver?
me too, I think I inserted double barrel adjusters on my partners CX bike on one cable when I re-plumbed itThis thread means I’ll definitely be sticking with a simple barrel adjuster on my gears. Easy to adjust to bring the tension to just the right amount after clamping a new cable.
