Tyres..Mich Pro 4 endurance or Conti 4 Season..
Vertego
Just reflecting on the meaning of life.
North Hampshire
By the way Pr04 is the old model,Michelin have changed and supposedly improved the PR04 range to be called Power. The new Power Endurances do not have the re-inforced sidewall that the old PR04 had.
And I've managed to cut the sidewall within 500kms.
Otherwise, I find the Power Endurance 25mm ride just fine, wet and dry. I'm playing with pressures - currently running at 90psi front & 95psi rear (I'm 88kg) and they are just fine. I was running at 105 f&r when I damaged the sidewall, which did not cut through totally.
Jason
Carnaby Street
Have 4 seasons (700 x 25c) on my road bike. So far so good with 300 miles
RoubaixCube
~Tribanese~
London, UK
I had Pro endurance v4s for a month on my triban. While i did like them a fair bit. I suffered one P+ so switched over to conti 4S which I've been running for at least 6 months if not a little longer and not had a single issue
I also run Vittoria Rubino Pro's on my Carbon which i take on a commute at least once a week if the weather stays dry. I've ran these tyres for well over a year and so far so good.
Your mileage may vary.
