Tyre width & mudguards for commuting
rob7222
Hi, I'm currently riding on 700x23's with mudguards on my commute to work (11.5miles). I'm thinking of ditching the guards and getting some 700x19's - is this likely to cut some time off my commute, how much could it impact on my comfort (specifically the tyres) and will I need to buy a new wheelset?
Cheers guys.
Tyre design, construction, materials and inflation pressure have more effect on rolling resistance than cross-section. Comfort though is entirely dependent on volume. A good quality 28mm tyre might have better rolling characteristics than a cheap 19mm but a larger tyre will always be more comfy than a skinny tyre.
Unless you are racing I would err on the side of comfort, for competition the rolling resistance advantage of a few microseconds makes sense, in the real world of potholes and greasy streets a bigger tyre provides better rim protection and a larger contact area.
If you want to go faster work on the aerodynamics of your riding position, at 20mph 80% of your effort is being used just to overcome wind resistance.
Having gone through the 1980's fad for narrower and narrower tyres, I'd bet that you would regret switching to 19mm. Pro's ride 22 - 23mm because they offer the best compromise between performance and comfort, and for commuting 25mm would probably be more reliable without making you any slower.
gbb
Peterborough
Agreed.
It's no accident i rode my evening circuit faster than ever before a few nights ago, because i've ony just started using the drops after 6 years of roadbike riding. You very quicky find yourself doing an extra 1 or 2 mph when on the drops...and you dont even seem to have to try any harder.
