Sheldon Brown has the needful, along with how to measure the rim:
https://www.sheldonbrown.com/tire-sizing.html
Anyone know if 1.25 inch tyres are safe to fit to 25mm internal rims?
Sheldon Brown says "Note: This chart may err a bit on the side of caution. Many cyclists use slightly wider tires with no problem."Which is still much different to other charts.
What do you mean by "cracks" please? Why will it be harder to balance (with narrower tyres)?make sure there’s no cracks when mounting, It might be harder to balance, so be careful
