Tyre & Tube Change
mick1836
Have just changed the knobbly Continental Queen 26" x 2.2 tyres for a pair of 26" x 2.00 Schwalbe Marathon Plus which I fitted and liked on my previous cycle.
When fitting those tyres on my previous bike I had problems getting the tyres to fit centrally on the rims so I took it to a cycle dealer who fitted them and said the problem was I needed to fit new tubes?
Because of the previous problem I also fitted new tubes with presta valves and bought a pair of 26" x 1.5 - 2.1" Halfords tubes.
The first tyre fitted was the front which went on quite easily, the tyre wall indicates inflation pressures between 35 - 70 psi so I was hoping to inflate to 60 psi, however on reaching around 50psi there was a loud bang
and the inner tube with large hole appeared between the rim and tyre.
I then despite the advice fitted the old inner tubes which are 26" x 2.2 - 2.4 and all is well, only inflated to 50 psi so what do you think went wrong?
1. Trapped inner tube?
2. Faulty new inner tube?
3. Inner tube 26" x 1.5 -2.1 to small?
4. Over inflated?
Thanks
lpretro1
U didn't seat the bead of the tyre properly in the rim - simples - so when you inflated iit the inner tube poked out under the bead and BANG!
Pale Rider
What age is the bike?
Some older bikes have wide, flat, rims which don't like modern tyres which are designed to fit on narrow, almost V or U-section, rims.
Ajax Bay
East Devon
4. Over inflated?
None of the above. Probably what @lpretro1 said, possibly caused by wide rims alluded to by @Pale Rider . Measure between the rim 'inner edges' to find your wheel rim width and check that a 2" tyre is compatible (Schwalbe chart). When inflating tyre, pump a few times and then bounce it round and also visually check that the beads are seated all round both sides.
swee'pea99
Almost certainly 1. It happens. I did it just the other day, and I must have repaired/replaced several hundred tubes in my time.
Ajax Bay
East Devon
OK, OP, what do you mean by 'a trapped inner'. I interpret that as you having trapped the inner with a lever when you struggled to get the M +s on.
Tim Hall
Crawley
2 and 3 aren't the cause. If in 1 you mean tube trapped between tyre and rim , then that's a very likely cause. If the rim isn't hooked or the wrong width then 4 is possible. However as the new tyres aren't that far from the width of the old ones, I'd say the rim width isn't an issue.
The bike shop who said new tubes are needed have "interesting" opinions.
Ajax Bay
East Devon
M+s are more likely to go on more easily (I mean less *** difficult) if the inner is on the small side. Talc. So if the previous ones were flabby 2.0-2.5" ones (and we don't know what they were), I think OP's LBS's opinion is valid. If there's an option, go small (ie narrower). Lighter, probably easier to fit, and entirely fit for purpose.
mick1836
mick1836
The bike is a Cube AMS 130 Pro not sure of it's age possibly a 2012 or 13? Think Cubes age goes by colour or is its year of manufacture within its frame number?
