Tyre pressures and the cold
chris-s
Truro
Such a nice morning I decided to ride to work, retreived the bike from the garage (~3 degrees C) and the tyre pressures were down around 60-70 psi so pumped them up to 120 as normal. The bike is now sat in the office and I suddenly thought 'are the tyres going to go bang' now it's in a warmer environment?
Chris
CanucksTraveller
Hertfordshire
Shouldn't have thought it would cause any significant problems... physics is a distant memory but I don't think there is a huge pressure differential between the temperatures we're talking about. It will differ, but not nearly enough to blow your tyre off.
Physics is a long distant memory for me too....but isn't pressure/volume/temerature calculated on the Kelvin scale?!?! There's little difference between 275K (2C) and 295K (22C) in terms of ratios - you should be fine.
CanucksTraveller
Hertfordshire
An average change of about 7 or 8 PSI then, assuming a moderately warm room (22 Celcius) versus a cold outside road (1-2 celcius).
I'm not even sure I'd notice that on a road bike.
Norm
If the figures zoxed posted are correct, then moderately warm (and I'd call 22 celsius pretty bloody hot!) to cold is only a change of 35°F or about 3.5psi.
To make the pressure change by 8psi needs a temperature change of 45° celsius, which is quite a lot.
CanucksTraveller
Hertfordshire
Oh yeah. Back to school for me. :biggrin:
potsy
Rambler
My Armchair
Very sure. :biggrin:
A temperature of 20°C is the same as a temperature of 68°F.
However, that's not the same as saying a temperature change of 20°C is the same as a temperature change of 68°F.
0°C is 32°F. ;)
You are Mumbo Jimbo and I claim my £5
Dan B
Disengaged member
I did once have a tyre go bang when left outside in the warm, but I think that was the effect of direct sunlight on it not just ambient temperature
100psi is about 7 or 8 atmospheres, iirc. Any changes in atmospheric pressure that are going to affect your tyres, I reckon they're going to affect your lungs first ...
