Felix79
- Oxford, England
I wouldn't lower pressure too much, due to the likelihood of pinch flats, bit 700x28s do provide a cushiony ride.
Please excuse my naive questions, I only got back on a bike again after 15 years yesterday. "Normally" a tyre on a road bike has a max pressure of 120'PSI (I think I have a 23mm on my bike, which the previous owner had pumped up to 120'PSI), so if the larger 25mm or 28mm tyre has the same value of max PSI, is it ok for me to drop it by around 15'-20'PSI (around 100'-105'PSI)?
Also is if I am reducing the PSI, do I need to have the same pressures front and rear, or are you meant to have more pressure in the rear tyre due to the extra weight?
Thanks in advance for replying to my noobie questions.
