Tyre going flat but no hole in tube
Loch side.
Not as daft as it sounds.
Nitrogen being less prone to leak from the tyre than air.
https://www.popularmechanics.com/cars/how-to/a3894/4302788/
It is as daft as it was intended to sound. That old nitrogen-in-tyres thing keeps on going round and round. It is just a way for tyre companies to charge for compressed air, that's all. Just because it is used in F1 doesn't mean it makes sense in your Morris Minor.
Air is great, but bubble-free and extra-thick is of course better.
andrew_s
Gloucester
Keep on pumping up your inner tube OUTSIDE the tyre, until you hear a banging noise, and voila, you have found your hole.
If you stop pumping just before the tube goes bang, and check for leaks then, you stand a much better chance of finding the hole, as it will have stretched with the tube and consequently be leaking much faster.
If you just change tubes without finding the leak, there are three possibilities:
a) It's a dodgy valve, in which case you are OK.
b) It was a puncture, in which case you'll have another flat tyre from the un-located sharp object in the tyre after a few days.
c) It was chafing from a mis-placed rim tape or similar, in which case you'll have another flat tyre in a couple of months.
Ajax Bay
East Devon
Have you tried pumping it up with thicker air?
An estimate of the difference in leakage rate between an air-filled tyre and one filled with Nitrogen is that the air leaks 1.6 times quicker.
So the tyre at the same pressure (100psi, say) left for a week (ceteris paribus) filled with air might drop by (say) 3.2psi as opposed to the N2 filled tyre only dropping to 98psi.
