Maz
Hi
When I turn the crank, there is no drive (Specialized Allez). Then (if I'm lucky) it starts working again, then stop again, then works again.
Now, I've had this problem before and it turned out the pawls were sticking inside the freehub. On each previous occasion it was in the depth of winter on a (freehub about 2 years old) when the grease in the freehub froze up.
I only changed the shimano freehub in January this year. New bearing fitted too.
Should the freehub last longer than this? Could it be a different problem?
How can I temporarily service the freehub?
Thanks
Thanks
