PaulSB
- Chorley, Lancashire
If you can find someone who knows what they are doing, it is possible to bend the stays out to allow a wider hub to be fitted.Speaking as the proud owner of a bike that has a wide modern hub squeezed into a narrow 80s frame can I just say: Don't do it. Getting the wheel in and out is a monumental PITA and takes quite a bit of brute force and ignorance.
That size wheels are widely available, but this bike requires that the hubs are 126mm OLN (width of hub) whereas most wheels will be 130mm OLN. So the OP needs to know what's what if he procures a new (to him) set. And any new wheelset is unlikely to have these lovely wide flange hubs, except at considerable expense.700c size wheels are absolutely everywhere in the cycling world,
Replacing a 700c tubular tyre rim for a 700c wire bead clincher tyre rim is even easier, it's a straight swap.
) please consider replacing that flouro green bottle cage with a simple nude aluminium one.I really must disagree with Dogtrousers about bar-end shifters. We called them handlebar control and if fitted properly and the cables routed neatly were something, in my opinion, which made a bike resemble a work of art. See the accompanying pic. of Rik van Looy - The Emperor of Herentals alongside two of his Red Brigade team mates in T.d.F 1965. Not much cable poking out there.Personally I wouldn't return it to bar-end shifters. Partly for looks - they have extra loops of cable poking out all over the place and would give the bike a more "touring" than "sporty" look.
Cables all over the place.Not much cable poking out there.
I guess you've never owned a pair of wheels with hubs with large flanges and they tend never to make it to a skip or tip. Think of the geometric benefits besides the aesthetic attraction.
I just like the look of them; they look different; I can't comment however on their technical merit; but they do look good and as I know the person who originally raced this bike; I'm sure that they were chosen with some technical advantage.Correct, have never acquired a machine with such wheels fitted. Not that struck with the look of them, TBH. I suppose there's a marginal advantage to having shorter spokes for a given wheel size, but I doubt it's very significant given spokes work under tension.
