Yellow Saddle
- Loch side.
Have to dissagree @Yellow Saddle ..
my tubeless wheels..ust hold the air for months..
i change the sealant every yr or when changing tyres..
i use a track pump..no probs..
no corosion..
no punctures..
Just good grip and no worrying about flats..
poor instalation may cause many probs and the wrong tyres..
I am not sure where we disagree.
I explained that non-UST tyres don't hold air well if they dont' have enough rubber in the sidewalls. UST tyres by definition have enough rubber.
Sealant has a limited lifespan. It is type and temperature dependent. I didn't go into detail but acknowledge it.
A track pump can inflate a UST tyre from new. Agreed. But won't do that on most non-UST tyres. Keep in mind that the UST logo costs money and supports the French, so some companies kick back against getting certified but still have good juicy tyres which will pass USB certification if enough money is paid to the Champaign drinkers.
No corrosion - yet. Dependent on sealant and CO2. The latter turns some sealants into acid. Ammonia-based sealants are alkaline, which is a problem for anodizing.
No punctures. Technically plenty of punctures but no leaks.
