TRP Spyre upgrade for Ribble CGR
kingrollo
The tektro brakes on my ribble cgr aren't performing that well. its my winter bike so don't won't to spend loads - but have heard good things about trp spyre - but no sure what to buy - see photos of ribble tektro below - presume I need flat mount ? - but them some sites recommend you need an adaptor ? - any
advice welcome.
Cycleops
Accra, Ghana
Not sure but I think Spyres are post mount, so you'll need an adapter. Maybe someone can confirm.
I'd also like some so I'd be interested in finding a stockist if anyone can help with that.
Odd securing arrangement on that rear caliper.
kingrollo
kingrollo
Merlin, Pro Bikekit have stock - there is a flat mount and a post version. not sure if I could use the existing adapter
Cycleops
Accra, Ghana
I think you'll need a post mount adapter like this:
si_c
Wirral
You need the flat mount calipers, no adapters are necessary. You already have the correct spacers for the rotor sizes you are using, so nothing else needed.
I'd suggest getting some compressionless brake housing though - replacing what you have now will ensure they work that bit smoother, and whilst you're doing that you may as well replace the inners too.
I like Skol
A Minging Manc...
Just checked my bike because I wasn't sure about the rear adaptor. Turns out they are direct mounted when running 140mm discs.
Front:
628044
Rear:
628045
kingrollo
kingrollo
They simply need to be adjusted then...
They probably need new pads as well. but If I am messing with pads and adjustments - I feel I may as well upgrade as tektro don't have the best reputation.
.......Waits for someone to post that if correctly maintained tektro brakes are as good as anything!
iluvmybike
Your talking £5-6 for a set of pads for exisiting brakes and a few minutes adjusting v buying a complete new set - which will also need to be adjusted when you fit them? So it is messing whichever way you do it?
Could sort of understand it if the brakes didn't stop you but they do - you just need to back the cable adjusters off a tad
  • Like
Reactions: C R
kingrollo
kingrollo
With respect the original post was asking about compatibility and which parts I needed to buy. If you want to start a separate thread about the performance and maintaining tektro brakes thats fine.
