Deleted member 35268
Am pondering whether to move to a Double chainset. Currently using Triple Shimano Tiagra, 9 speed, not sure the crank length or current ratio exactly.
Anyways, I already have replacement (double) shifter set with right hand 9 speed in black so would look good.
I am certain I can use the same front derailleur, and just tweak the limiters.
So, aside from the pain of setting up a triple, would there be any weight advantage so to speak ?
A few decent discounts around such as http://www.ribblecycles.co.uk/shimano-sora-3000-double-chainset-5-arm-9-speed/#pid=34509
Double Ratios
34/50
Current triple (probably) Ratios
30/39/50
Double chainsets certainly seem a little cheaper to buy than triples.
Double Ratios
34/50
30/39/50
