oldgreyandslow
- Farnborough
I've had a few issues with my 105 equipped Boardman and the transmission seems quite noisy - rumbling a bit in the big chain ring from the rear I think. I realise that description isn't helpful so I'll run through the history of the bike and hope someone can suggest a few things to check.
Initially after a few months there was some creaking from the bottom bracket – Halfords changed the BB30 bearings under warranty.
I changed the rear cassette from a 12-25 to 12-27, the cassette was a CS5700 105 unit, however the one I removed had no spacer behind it and the Mavic Aksium instruction book that came with the bike seems to show it needs one (see attachment) is this correct? Is this correct, I didn’t fit a spacer but I think I still have it somewhere.
The gears still seemed to be running fine at this point though.
I flipped the stem to try to get a more comfortable position, which seemed to upset the front mech, I tried sorting that, the action was also very stiff and the lever broke. Thankfully Halfords fixed that and I thought all was well. But after a while shifting became noisy, I assume d it was set up.
I decided to revert to the original position with the bars and flipped the stem back and attempted to set the front and rear mech’s up. I have to say though that having had campag for all my previous bikes I found the shimano set up instructions and procedure a right pain in the rear, so much so that I resorted to the LBS (shame on me!).
I put the bike on the stand and it seems to run through the gears OK, no rubbing on the front mech plates and it shifts OK at the rear but it seems to have developed this rumble when on the large ring.
In addition a couple of the rear blades spokes have twisted, I have reset them but wonder if I should get the wheel trued? I have the rear from my Campag bike, although unfortunately the bike itself is irreparable as a result of last year’s RTC, I was thinking of changing the freehub from this bike onto that wheel to see if it makes any difference, good idea or not?
Apologies for the long winded post, any advice or suggestions most welcome.
Thanks
Thanks
