No it's an Hi8 analogue with s-video and composite output, I've got the X50.
As Peanut suggests, if your DVD recorder has a Scart input, you can use a Scart adaptor to attach your video lead from the camera direct to the recorder. It also may well have a composite input - composite consists of 2 audio channels (red & white) and a video channel (yellow) which is how it may be marked and to just to confuse things it may not use those colours but just be marked audio and video.
It could also have a single s-video input, which is the single black lead. That by itself, carries all the audio and video info and you don't need the other lead.
If you can get the signal from the camera to work you should be able to record it.
