figbat
Former slippery scientist
- South Oxfordshire, UK
The ATC does make a ’priming’ noise when powered up.
I wonder if this is what I can hear becoming operable, when I insert the 13-pin plug into the socket
It almost sounds like a solenoid actuating
https://www.alko-tech.com/uk/al-ko-trailer-control-atc
At the bottom, in the small print, it states that it's a standard fitment, below the 'Fact-File'
https://www.caravanguard.co.uk/news/review-of-the-coachman-vip-520-4-caravan-3881/
I was out in mine over the weekend. This is the ATC LED. On my Bailey it’s on the plastic shroud that covers the A-frame.
Yes, that's what I refer toBy ‘car bra’ I assume you mean ‘towing cover’? We use one on ours - the supposed advantages are twofold:
- It keeps the front clean of road grime, meaning in wet conditions you don’t arrive with the front covered in dirty spray and needing a clean
- protection of the front panel and especially the front windows from flying debris such as stones.
I can see both sidesAlso, there are two camps when it comes to storage covers. There are those that like the fact that they keep bird droppings, tree sap and general detritus off of the van. Others argue that they get wet and limit airflow and can cause damp as well and rubbing on the paintwork and dulling the exterior.
