stearman65
- Southport Merseyside UK
I've begun a thread on this in the motability forum, but thought this was a more appropriate place for an answer. The rear fixed sprocket is 105mm dia' over the teeth (not sure how many teeth) it will/ could take 140mm dia'. The front chain wheel with the pedals is 80mm dia' & could take 130mm dia'. Currently, the fixed gearing is too low. I don't want to alter the front c/wheel if possible, I want to fit a 6 speed cassette with free wheel. Is there a formula for working out how many teeth to wheel diameter. From my old cycling days I remember the larger the front chain wheel, the higher the gear & visa versa for the rear rear sprockets. What size cassette would you suggest to match the front chain wheel, with the middle cog around the same or slightly higher than current. Hope this make sense.
https://www.flickr.com/photos/eric_shepherd/albums/72157671957784806
