I disagree with 4F. And noone seems to have offered any practical help.
The bike has two gear changers, which appear to be twist grip ones. The left one controls the front gears (where the pedals attach to the bike) and the right one deals with the back (a cluster of 6 cogs)
YOU CAN ONLY CHANGE THESE GEARS WHEN PEDALLING.
Very roughly you want the left gear changer in the Number 2 position on flat roads, number 1 position going up steep hills and number 3 for downhills. Practice will tell you how this feels.
The right gear changer (assuming it is set up right) should have the "easiest" gear (ie the one that feels least effort) as number 1 and the hardest as number 6.(you also should go and get Halfords to set up the gears right as it sounds like a slight misalignment)
Get a friend to help you get it into L2 and R1 (should be on the middle ring at the front, and biggest cog at the back). Pedal off down flattish road, and use right hand changer to go up and down through gears.
Find a slight uphill. As you go along the flat, once you start to struggle, change to L1 and R4 (approx). Then as it gets harder, changes to R3,2 ,1 etc. When you turn round to go downhill change to L3 and then change to gears R3,4,5,6, etc..
Contrary what someone said above, for the bike you have if you pedal down hill in L3 and R6 you should still be able to apply pedal pressure at 25mph+
ENJOY
You're right about the OP, but it is surprising how many people are totally confused.Um, did you read the OP? ... etc.
I'll have to try and follow some of the suggested guides to fix it or take it back to "cough" Halfords as it's only 2 days old! Does this sound like an Indexing problem or a high/low problem?
. Yet another guide for you to look at lol but this one helped me.
but that's for another post lol.Ok, so I flipped the bike upside down an had my wife move the cranks whilst I was selecting the gears. The rear gears definitely have issues. Most of the time when switching from 1-2 or 2-3, it can't transition properly and slips to the next cog, so when I move it to 5 on the shifter, it is actually on 6. Moving to 6 then does nothing (presumable because it's limited). I'll have to try and follow some of the suggested guides to fix it or take it back to "cough" Halfords as it's only 2 days old! Does this sound like an Indexing problem or a high/low problem?
I think half the problem with the hills is the gears not engaging properly. I'm glad to know that I *should* be able to peddle on the downhill because I want to try for a steadyish cadence. At the moment I'm freewheeling down about a 1/3rd of my route which isn't brilliant for cardio (although it does give my poor quads a rest)!
When I had the bike upside down, the front 1-2-3 transitions seemed to work nicely, but I am struggling to make the transition to 1 for very steep hills. The chain won't shift over from the middle cog. I've tried holding it firm for a few seconds and tried to push past 1 on the switcher but no joy.
Anyway, all a learning experience!
Thanks again for the helpful advice.
You get a warm and tingly feeling when doing things for yourself? I know I do![]()
I guess that my expectation was that I could go downhill and still pedal to keep my cadence up - perhaps that is a false perception and I should just freefall? With that in mind, should I just stick to a medium to low gear on the way down, ready to engage again on the way up?
Incidentally, if you are in a dip and get it just right, amazing slingshots up the other side can be achieved.
