HappyToNotFallOff
Hi there,
I've just bought an 18 speed bike. The last time I was on a bike was when I was 8 years old (23 years ago!).
On the two run outs I have had with the bike, I'm getting confused with the gearing - with hills.
Peddling is MUCH too easy when I am on even the slightest of down gradients. In most cases I end up in a freefall and the pedals do nothing. I've switched to the highest gear 3/6 but it makes no difference. So I freefall to the bottom of the hill. As I am getting to the bottom (ready for a steep climb), I can't pedal in anticipation for the climb because they just spin and I can't change to a lower gear for the ascent because the derailleur won't work without me pedalling. I have to wait until I'm on the ascent and slowed right down before slogging away in a high gear to the top!
Another issue with the bike is that when I set the rear gear to say 3 on the handlebar, the 4th cog is engaged, so it's always 1 out. Is this just a matter of adjusting the rear derailleur?
Thanks
Thanks
