I agree to some extent for the need for them - having myself spent years assembling machined parts and having a fairly well calibrated wrist. However, given the cost of a basic wrench against replacing a pair of carbon bars or a stem due to crushing / stripped threads, then the cost is probably worth it in the long run. However, I wouldn't recommend using basic allen keys either - not unless they're a reputable make with machined ends, rather than the cheap ones that often appear to be made from plasticene. Get a quality set of hex-bits, you are far less likely to 'round' the heads too. In particular, 4-bolt stem faceplates on carbon bars are fairly critical in terms of getting even tension - particularly with 4mm screws which are inclined to snap if overloaded
